Jump to Menu
Visual Paradigm 教程
我們的教程專就各類您關切題目提供詳盡的介紹和指引,讓您成為軟件開發的專家。我們會定期上載新的教程並更新現有教程,歡迎常來查來,以幫助您掌握使用 Visual Paradigm。
最受歡迎的教程
How to Merge Actors in Use Case Diagram?
51,123瀏覽次數
  • Removing duplicate model elements
  • Merging a duplicate master actor
How to Use C++ Round-Trip Engineering?
50,322瀏覽次數
  • Generating ANSI C++ from Class Diagram
  • Updating UML Class Model from ANSI C++
Factory Method Pattern Tutorial
50,208瀏覽次數
This tutorial is aimed to guide the definition and application of factory design pattern. By reading this tutorial, you will know how to develop a model for the factory pattern, and how to apply it in practice.
Comparing Database Schemas Visually
49,647瀏覽次數
Teach you how to use the visual database comparison utility, Visual Diff to find differences between two databases.
How to Use Stereotypes and Tagged Values?
49,512瀏覽次數
  • Create stereotypes
  • Define tag definitions
  • Set tagged values
How to Animate a UML Sequence Diagram?
49,402瀏覽次數
  • Animating sequence diagram
  • Exporting Adobe Flash from sequence diagram
Proxy Pattern Tutorial
48,624瀏覽次數
This tutorial is aimed to guide the definition and application of proxy design pattern. By reading this tutorial, you will know how to develop a model for the proxy pattern, and how to apply it itn practice.
How to Create Requirements Spec. in Minutes?
48,409瀏覽次數
  • Writing a Doc Base
  • Opening a Doc Base
  • Generating a Document
Generate Hibernate Mapping for Oracle Database
47,986瀏覽次數
  • Creating object model from entity model
  • Generating ORM Source and Hibernate Mapping
How to Import Bizagi Project into Visual Paradigm?
47,509瀏覽次數
  • Importing .bpm file into Visual Paradigm
Previous 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 Next
創造美好 共同成長
OK
