Most Viewed Tutorials
How to Use Stereotypes in EPC Diagram?
25,498views
- Configuring a stereotype
- Adding tagged value
- Assigning stereotype to a shape
- Showing tagged values on the diagram
How to Bridge the Flows between Parent and Sub-Diagrams?
25,393views
- Elaborate model element with sub-diagram
- Link up the flows from elements in parent diagram to child diagram
- Show/hide in and out flows connector
Mediator Pattern Tutorial
24,802views
This tutorial is aimed to guide the definition and application of mediator design pattern. By reading this tutorial, you will know how to develop a model for the mediator pattern, and how to apply it in practice.
How to Hide-Away Toolbar Buttons in Visual Paradigm?
24,786views
- Using Customize UI dialog box
- Test customized UI
How to Extract Glossary Term from Shape Name?
24,349views
- Draw use case diagram for online wine shop
- Identify and describe glossary term
- Open a term from diagram
How to Define Custom Model Element Properties?
24,240views
- Defining Default Tagged Values
- Entering Tagged Values
- Showing Tagged Values on Diagram
User Story Tutorial - Using Tag
24,184views
- Why tagging is needed?
- How to create tag?
- How to add a tag to user story?
- How to filter the screen to show user stories with specific tag?
How to Customize Element Templates in Doc. Composer?
22,652views
Write your own element templates to use in Doc. Composer. In this tutorial, we will show you how to do this.
How to Maintain a Glossary for Multiple Projects?
22,512views
- Concept of centralizing glossary terms
- The steps to centralize glossary terms
