Jump to Menu
How to Bridge the Flows between Parent and Sub-Diagrams?
When modeling complex systems, we often use the sub-diagram to elaborate a particular elements in details. This helps to keep our design clean and context sensitive. However, in previous versions, sub-diagram didn't explain how the flows were associated between parent element and the child diagram. In Visual Paradigm, you can now display the in-flow and out-flow element in sub-diagram in certain situations, which helps you to identify the flows between diagrams.
  • January 13, 2015
  • PDF
In version 12.0, the element for the incoming and out-going flows are automatically pulled into sub-diagram when:
  1. Modeling the behavior of an action in UML Activity Diagram
    01 define behavior
  2. Modeling the detail of a submachine state in State Diagram
    02 create submachine
  3. Modeling the detail of sub-process in Business Process Diagram
    process
  4. Decomposing the process in Data Flow Diagram
    04 decompose dfd process
Once the sub-diagram is being created and the incoming and outgoing flow are pulled into the sub-diagram, you can then start modeling the sub-diagram from the incoming flow and end with the out-going flow.
05 model with in out flow
To turn on the in-flow and out-flow indicator, right-click on the blank area of the diagram and select Presentation Options > Show In/Out Flows.
06 turn on in flow flow
Once the In-flow and Out-flow indicator are shown, you can navigate to the parent diagram by double click on it.
diagram
What this Tutorial on YouTube
创造美好 共同成长
